RSorder OSRS: What Should You Do Instead
Stellaol
Post by Stellaol »
Steel Dragons — and by RuneScape gold extension,all metal dragons like Iron or Mithril Dragons — are slow,defensive,and dangerous. You'll need high protection prayers
Steel Dragons (and other Metal Dragons)
Task Weight: 7
Steel Dragons — and by extension,all metal dragons like Iron or Mithril Dragons — are slow,defensive,and dangerous. You'll need high protection prayers and decent gear to kill them efficiently,and even then,the loot is underwhelming compared to the effort.
Recently,Steel Dragons became weak to Earth Spells due to Project Rebalance,but it hasn't significantly improved XP rates. These tasks often require multiple trips due to their durability and strong dragonfire attacks,which is the opposite of efficient.
If you're thinking about unlocking Mithril Dragons as a Slayer option: don't. They're even slower than Steel Dragons and arguably more frustrating.
What Should You Do Instead?
To get the most out of your Slayer journey,aim for tasks that allow for multi-target combat using Ice Burst,Ice Barrage,or a Dwarf Multicannon. Tasks that fall into this category include:
Dust Devils: Can be extended and barraged in the Catacombs for fast XP and solid drops.
Nechryaels: Also great for multi-targeting with Ice spells,and have very profitable loot tables.
Smoke Devils: Can be burst with magic and are less crowded.
Bloodvelds (Mutated): Good for cannoning in multi-combat areas.
These tasks not only give great XP but also tend to pay for themselves through valuable alchables and rune drops. Make use of task extensions from your Slayer Master to buy RS gold maximize your time on these profitable,high-XP creatures.
