The Poisonous Concoction of Bouncing Pathfinder is a popular and effective build in Path of Exile (PoE), especially favored as a league starter due to its strong damage output, budget-friendly gear requirements, and smooth gameplay. This build revolves around the Transfigured skill gem Poisonous Concoction of Bouncing, a variant of the original Poisonous Concoction that throws a single bottle which bounces on the ground, chaining randomly while prioritizing enemies and dealing area chaos damage with poison effects PoE 1 Currency.
Skill and Mechanics
Unlike the base Poisonous Concoction, which fires multiple projectiles, the Bouncing version throws one bottle that bounces multiple times, each bounce releasing an area burst that can poison enemies. The skill consumes charges from a Life Flask to add significant chaos damage based on the flask’s recovery amount, making flask management crucial for maximizing damage. It requires an empty main hand and no off-hand weapon, emphasizing an unarmed attack style.
The skill has a 40% chance to poison on hit and benefits from modifiers that increase poison damage, attack and cast speed, and flask charge gain. The build typically uses the Brutal Restraint unique item to further boost flask effectiveness and poison damage.
Build Highlights
1. Ascendancy: Pathfinder is chosen for its synergy with flask uptime and poison damage, enhancing survivability and damage output.
2. Budget Friendly: The build is accessible for new league starters, requiring relatively inexpensive gear while still offering strong damage and clear speed.
3. Scaling: It scales well into late-game content, with options to upgrade gear and jewels to increase damage and survivability.
4. Versatility: Can clear maps efficiently and handle bosses with proper gearing and playstyle adjustments.
Recommended Gear and Gems
The build uses a combination of skill gems such as Poisonous Concoction of Bouncing linked with Unbound Ailments, Void Manipulation, Vicious Projectiles, Greater Volley, and Greater Multiple Projectiles to maximize damage and coverage. Defensive layers include Steelskin and mobility skills like Shield Charge or Flame Dash.
Key unique items include Brutal Restraint for flask synergy and Silverbranch for early leveling. The build also emphasizes flask quality and crafting to increase recovery and damage bonuses PoE Currency.
Summary
The Poisonous Concoction of Bouncing Pathfinder is a versatile, budget-friendly poison build in PoE that excels as a league starter and scales well into endgame content. Its reliance on flask synergy and poison mechanics makes it both engaging and effective for a wide range of players.
u4gm:Poisonous Concoction of Bouncing Pathfinder in Path of Exile
