Kent Tekulve (Submarine)
Signature Pitches: Slider, Sinker
Strengths: Consistent strikes, heavy sink on pitches.
How to Use: Use to keep hitters off balance with horizontal movement. Ideal against contact hitters.
All Sidearm Pitchers in MLB The Show 25
1. Randy Johnson (Sidearm)
Signature Pitches: Fastball, Slider, Curveball
Strengths: High velocity, devastating slider movement.
How to Use: Use the fastball to MLB The Show 25 Stubs set up sliders on the outer edge. Effective against power hitters.
2. Daniel Hudson (Sidearm)
Signature Pitches: Cutter, Slider
Strengths: Good velocity, sharp cutter.
How to Use: Mix cutters and sliders to jam hitters or get them to chase outside.
3. Dennis Eckersley (Sidearm)
Signature Pitches: Cutter, Curveball
Strengths: Great control and movement on cutters.
How to Use: Perfect for closing games, use cutters inside and curveballs low.
Tips for Using Submarine and Sidearm Pitchers Effectively
Mix Speeds and Locations: Because of their unusual release points, mixing pitch speed and locations keeps hitters guessing.
Focus on Ground Balls: Submarine pitchers especially induce ground balls, so pitching low in cheap MLB Stubs the strike zone is key.
eld.gg MLB The Show 25 Stubs: Sidearm
